查看: 121|回复: 2
[声学传感器] 【ams数据手册翻译】《AS3501_02_Datasheet_EN_v2》
发表于 2020-3-7 10:02:37 | 显示全部楼层 |阅读模式
8.1.1 General
The chip features one line input. The blocks can work in mono differential or in stereo single ended mode.
In addition to the 12.5-25k input impedance, LineIn has a termination resistor of 10k which is also effective during
MUTE to charge eventually given input capacitors.
8.1.1概况
该芯片具有单线输入功能。 这块功能可以在单差分或立体声单端模式下工作。
除了需要12.5-25kΩ的输入电阻外,在线输入端的设置电阻为10kΩ,这将会给输入电容器充电。
管理员
Rank: 9Rank: 9Rank: 9
发表于 2020-3-30 16:20:35 | 显示全部楼层
然后呢,没有后文了么,加油呀
2万
发表于 2020-4-24 11:12:14 | 显示全部楼层
学习学习新技术
您需要登录后才可以回帖 登录 | 立即注册
GMT+8, 2020-5-28 11:24 , Processed in 0.086732 second(s), 14 queries , MemCache On.
© 2001-2013 Comsenz Inc.
